DDRX360 said:but they are not easy to stay cool with such high clocks
Trinitrotoluene said:overclocking a CPU is so freaken pointless unless you are getting only 15 fps in a game and need a few extra to make the play more enjoyable(after already overclocking your GPU) or you are so impatient that you desperately need your encoding to finish a couple seconds earlier than normal. Other than that, its all about the ego.
DDRX360 said:Since they are already good whats the point?
Bullshit. If I overclock by 50%, it means my rendering breaks are 2/3rds as long. Waiting four minutes between renders instead of six minutes is a MAJOR productivity increase. It also means I'll have to take fewer rendering breaks as the interactive preview renderer will keep up better. Having all-night renders finish in six hours instead of nine hours is also a significant improvement.Trinitrotoluene said:overclocking a CPU is so freaken pointless unless you are getting only 15 fps in a game and need a few extra to make the play more enjoyable(after already overclocking your GPU) or you are so impatient that you desperately need your encoding to finish a couple seconds earlier than normal. Other than that, its all about the ego.
I think you're on the wrong forum dude.Trinitrotoluene said:overclocking a CPU is so freaken pointless unless you are getting only 15 fps in a game and need a few extra to make the play more enjoyable(after already overclocking your GPU) or you are so impatient that you desperately need your encoding to finish a couple seconds earlier than normal. Other than that, its all about the ego.
Daleon said:Now is that extra ghz going to speed up your porn surfing? Ofcourse not.
Is it going to make a big difference if you got a x800 or 7600? Probably not.
jreffy said:Yeah, but it will work WONDERS for my porn editing!
YES!!!aldamon said:You can watch HD pr0n with one core and encode HD pr0n with the other. Multitasking at its finest.
Pron should not taken lightly , its [H]ardcore or nothing.psychot|K said:Oh man I love pr0n.
That should be conroe's new slogan: "offical dual core processor of all things pr0n"
