- Aug 4, 2004
So, after my HTPC decided to crap out on me, I've finally gotten around to putting my "expansion project in place"
I now have a system acting as a fileserver/sagetv server and my old HTPC case is housing a client system (doesn't do any recording).
I've currently got 3 WD 500 GB RE drives installed in the file server using the onboard RAID5. The motherboard is an ASUS M2N-SLI Deluxe with a Athlon X2 3800+ processor.
If I'm watching a show on the client system and decide to copy a file to the RAID array, the video gets very choppy and stutters. Apparently, the fileserver is having issues writing to the RAID array and streaming a video at the same time (even simple MPEG2 standard def recordings).
I knew that there was a cost in extra CPU usage with onboard RAID, but I never figured it would be high enough to bring a media server to it's knees when just copying files
Would RAID 1 have the same issues (using the onboard RAID)? I could instead set up the 3 drives with 2 in RAID 1 and use the other drive for stuff that wouldn't matter if it went up in smoke.
My other option would be to buy a PCI-E RAID card, but I'm not sure if that will make enough difference to warrant the cost.
