Is the OCZ ModStream 450W enough for..
WanTeD
Is it enough for this system:
MSI Neo2 Platinum
AMD 3500+ Venice
BFG 6800GT OC
I plan to OC the 3500 around 300Mhz and the GT to Ultra Speeds..
What is, "that would be enough power," Alex.
I'll take "Flaming CPU's" for $200, Alex.
Marginal, I recommend going with the ModStream 520W, Antec NeoPower 480W or
the new Antec SmartPower II 500W ($67 - $75).
All are modular & have power to spare. ;)
_Korruption_ said:
Should be. List your entire config.
MSI Neo2 Platinum
AMD 3500+ Venice
BFG 6800GT OC
Western Digital 250GB SATA
A dual layer DVD Writer (Didn't buy this one yet)
Kingston HyperX KHX3200ULK2/1g (2x512 mb 2-2-2-5) TCCD
Audigy 2ZS
davidhammock200 said:
Marginal, I recommend going with the ModStream 520W....power to spare. ;)
Yeah. 2 whole more Amps on the 12V. Not even enough to light a cold cathode. :rolleyes:
When it comes to CPU's, Athlon64's take about as less juice as any of them. Ditto with ATI video cards. That said, having the 450W with it's 26A on the 12V rail, you have way more power than people with twice as much computer would even need. And at about $20 less than the 520, the 450 is a good value too.
