is the newer or older?
The 860 EVO m.2 SSD uses SATA, not PCIe - hence, it is far slower in both sequential reads and writes than its pricier 960 EVO version (only 550/520 MB/s for the 860 EVO versus 3.2/1.5 GB/s for the 960 EVO). Worse, the 860 EVO m.2 is supported in fewer systems than the 960 EVO (which uses PCIe) because there are some m.2 motherboards that only support PCIe in their m.2 sockets.
Like eagle said....big difference between the two, however, for most use cases you may not notice the increase in speed. But do beware of the compatibility issues with boards that only accept PCIe m.2!
Do you NEED an m.2. (i.e. for a laptop)...if this is for a desktop, if you want to save cash get a regular 850/860 evo SATA drive for much cheaper...if you want performance then get the 960 evo
