Is the EVGA SR2 Futureproof?
Sinsear
Well, it doesn't fully support Sata III and USB 3.0, but in terms of socket compatibility, will the chipset being used on the SR2 be around for a while? The next major update is Sandy Bridge, correct, but that's for another year, right?
Nothing is future proof. You buy the latest and greatest, you pay a price premium. You buy something of this "era", you pay a reasonable price. It all depends on what your money is worth to you.
Nothing is futureproof. You may gain an extra year of use IF you have very multithreaded software.
Comparison: How many folks are still using dual socket Pentium 4 based Xeons? Dual sockets didn't buy them extra life when the dual and quad cores came along.
Technology moves forward. Get it if you have a "need" for it right now, but not otherwise.
It will future proof for maybe 2 years at most and thats if you STOKE that board with the 2 fastest CPUs and maxed out the GPUs and Ram along with Raid 0 SSD drives. Most likely it can be matched in 2 years by a single CPU, and single video card and most assuredly about one kilowatt less energy use.
Are you kidding...this is what powers the Enterprise!?!?!?!:eek::eek::eek:
They probably said that about something they put on the original Enterprise too.
Now they say something like "hah dude remember when you thought that flashing orange light that told you when the shields are down would never get replaced"
Ok, well, perhaps I shouldn't have used the word "futureproof". What I should have used is: "Will this board remain competitive in terms of performance for the next year or two?" Also, can a 975 outdo a skulltrail system in terms of raw processing power?
Well yeah, in 18 months your SR2 system is still going to be fast, but I think the point is that no matter what you buy, in a year or two it will be always be slower compared to just-released products. So unless you need absolutely ridiculous performance right now, you might as well get something cheaper that's a much better value... a single-proc 1366 board with the i7-930 and a 5870 is going to be way less money but still give you good performance. And if you take all that dough you would have spent on the SR2 and save it, in 18 months you'll have enough to upgrade your mobo/cpu/graphics card to current tech.
Yes it will remain competitive as long as you keep funding it. You buy a couple of $300 procs now, you'll still need to upgrade procs in the next year of two, even if it is with another set of $300 procs.
As far as a skulltrail system, I'm pretty sure that an i7 @ 4.0Ghz is faster than a skulltrail system. An i7 @ 4.0Ghz is just as fast as a dual 5520 system I believe, with respect to folding@home.
I think this board will be fairly well future proof, I mean 24 cores versus a single CPU board will still stay competitive, as long as you stay on top of it, as well you have the ability to pump 24GB of RAM into the board which will better fuel the fire, and it already has future tech such as USB3.0 and SATA3 so you should be able to play along with the other future builds.
depend on what you using it for <<<
for gaming ???
tell me one single game need more then a single core i7??? (with 4 core+ 4 HT core)
having that board will not have the gaming any better,.,,
looking back at the last 40-50 years of personal computing, I'd say nothing is future-proof...
i do a lot of x264 encoding, so that is something that can use 16 or 24 theads and put them to good use. to me it would be worth it to shell out $600 and another $750 in quad core xeons (overclocked) to almost cut down my encoding time in half.
another example is running multiple vm's in parallel. those are the two situations that would have a real world benefit to me.
if you are looking at this for games then yes it is a waste.
I'm assuming this statement is made with the assumption that the 5520's are stock clocked (as there hasn't been a server board with the ability to OC yet)?
Uhh, I don't believe that there are any 12 core CPU's out on the market at all (the most cores so far on a single CPU is 8, which is the Nehalem-EX server CPUs which use a LGA1567 socket). I think it also supports 96gb of RAM as well (12 sticks of 8gb RAM).
he meant 24 threads. 6-core X 2 (6X2=12 threads per CPU X 2) = 24 threads
Sorry, you are correct although AMD bulldozers are coming, I meant 24 Threads, dual 6coe Xeons with HT on...
And yes, surely it is capable of some Ludicrous mount of RAM as well lol
Yes, stock clocked 5520. Here's the thread that points this out. You'll see that an i7@4.0 will pull around 29k PpD while the 5520s will do between 30k and 31k PpD, but most of the people folding on an i7@4.0 are also GPU folding, which hurts the CPU PpD a bit (around 2-3k). So in then end, an i7@4.0 is just as fast as dual 5520s, and should demolish a Skulltrail system, which I mentioned above.
X58 or P55 boards will work/play games very well for the next three years with a good video card which can be upgraded to meet any future needs. No one really needs this new toy unless you have money to burn and want those bragging rights.
Even my eVGA 780i board with a 295 GTX card does every thing very well and can keep going for another year or so.
I bet the X68 board (Rumored) that will replace the X58 will perform very close to the SR2 and cost much less.
http://www.guru3d.com/news/intel-x68-rumor-issueing-usb-30-and-sata-6gbps-in-q2-2010--/
I just have one question: why? Something like that SR2 is only practical for numbers crunching or high end video rendering that can really take advantage of all those CPU cycles. A stock i7 has more memory bandwidth than can be used by even the NEXT generation of vid cards. Unless you're going for the title of "Biggest E-Penis", it's a waste. Take the money you would spend on the extra CPU and memory, get yourself a second 5870 and be happy knowing you made a sound investment that will play all your games on max settings.
I wouldn't call any board "future proof" right now that doesn't offer native SATA 6Gbps and USB 3.0 on the chipset. IMHO we are in a limbo period where buying ANY new motherboard is a waste of money until those features are standard.
My feeling is there is a whole lot of shit on that mobo to go wrong....
Somewhat agreed. Many folks will simply never need Sata 6Gbps. I think USB 3.0 is much more likely to have impact in the next few years.
nothing is future proof. Most tech last for about 4 years before you would want a new one.
