Is the Droop Mod worth it?
woolly
I have P4 2.8C @ 3.42GHZ with a P4C800 motherboard and Kingston HyperX PC4000 RAM at Dual Channel.
I am having trouble getting past 3.42GHZ without the computer hanging at Prime95.
I have got the POT's for the droop mod and I was wondering if it was worth doing and if it would help at all for me to reach a higher overclock.
thanks for your input :)
I'd say it would be worth it if you can establish the voltage is holding you back. Say its drooping too low on load and causing instability, maybe try boosting voltage a bit higher so it droops to a normal level and see how it handles that. I'm in same situation as you but I never got around to doing the mod.
