Lol. It's confusing because I was looking at reviews of the cpu and video card. Each almost using 300w at load. So I wasn't sure. Thanks guys.
Actually, those "300W" results were for an entire system using either of those components (this includes CPU, mobo, GPU, drives, RAM).
So even a good 400w psu would be fine.
Likely so, unless you're overclocking. Even at stock, I recommend a good 500W PSU for that system because PSUs run at their most efficient at between 50% to 60% load. If you're overclocking, you might want to go 550W to 650W.
Remember, you're not at 100% load all of the time. The vast majority of the time, a PC will be at partial loads...probably 150w or so. So in actuality, a 400 unit would probably be more efficient in a typical usage setup. As always, there are special cases.
