Is the Catalyst Control Center worth it?
G-Nome
'It' meaning the used resources and large file size? I usually just download the display driver, but was wondering what all you peeps thought.
Why don't you try it out for yourself and see what you think. I use it mainly because it keeps my clocks since when I try atitool or atitraytools my clocks usually get deleted.
Personally I hate it ....slow bloated mess.
Must have been done by microsoft.
I don't really like the bloat and it doesn't seem to offer anything over ATT. About that, you just need to set up a profile and then have it load that profile at startup.
I just jumped the ATItray Tools wagon and it feels great. But I have slight problem. My overclocking seems to be working perfectly when using ATI overdrive 3 for overclocking. But when I try to overclock from the defaul overclocking windows it does not go so smoothly.
I set my clocks and try to save it as a profile, but all I get is X1900 basic clocks. Heres a picture:
Help a Tray Tools newbie out. I have no problems using the Overdrive 3 for OC, but still makes me wonder, why I cannot create OC profiles in normal Tray Tools OC. I did try this with ATI hotkeypoller disabled and enabled, no change :confused:
Using 6.12 drivers and the rest of the rig is on signature.
edit:
Crap, Atitray tools wont let me enable my projector on secondary DVI connector :( Back to 6.12 CCC ..
