Is Syntax the same company as Chaintech?
NoodleTech
Hi, I just reformatted my friend's computer and I'm downloading drivers for it. The manufacturer of the motherboard is Syntax and the model number is S865PE. When I google this, a board from syntax and a board from chaintech come up both with the model number S865PE.
I can't seem to locate any syntax drivers, so I am downloading chaintech drivers right now. Is Syntax the same company as Chaintech? Is the S865PE from Chaintech the same as the S865PE from Syntax? If not, where can I find drivers for his motherboard?
Please help, thanks!
One way you could check it out is to look at pictures of both side by side. If they are identical, it's a good bet they are made by the same people.
IIRC, isn't Syntax a white-box OEM? Maybe they're just rebadging chaintech parts.
You could also just download drivers for the chipset on the motherboard from the chipset manufacturer. If the name involves any sort of logic, the chipset would be an 865 chipset, and you could get those drivers from Intel's website. Also after you install your network drivers, you normally can go to windows update and it will find other drivers for you (such as sound, modem, video, etc.)
Jason
You should be able to just read the ICC's on the board to see who makes them and then go download the newest drivers. Realtek makes a lot of ICC's for budget boards (sound and network specifically).
