Is SLI worth it?
Arch
I'm spec'ing out a new system. I have up to $2k to spend. Right now I have two options:
Non SLI motherboard and a single BFG 7900GT OC (plus the rest of the system) = $1600.
SLI motherboard and a pair of BFG7900GT OCs (plus the rest of the system) = $1950.
Is it worth the extra $350 to go with the SLI motherboard and dual 7900 GTs? I game on a Dell 2005FPW, so I like to run games in the native 1680x1050 res if at all possible. At the moment, with Need for Speed Most Wanted and Oblivion that isn't possible on my 6800GT (AGP).
Thanks!
Depends on your monitor. If you have some 17 inch crt that maxes out at low res... no its not worth it. If you have a 38" flat panel with res to boot.. then yes.
At what point does it become beneficial? 1600x1200, or greater? What about 1280x1024?
Or more to the point, when does it become more cost effecient?
i dont think that it will make a huge difference in todays games at 1280x1024 but at 1600x1200 yes, i think it will. personally i dont think sli is worth it becasue not all games support it and on most mobos the speed of the pci-e slots is cut in half. and, once again, thats why i like my 17 inch monitor, because native res is fairly low.
How often do you plan on upgrading? If you have 2K for a system now, I would imagine that a year from now you will have $400 for another graphics card. In that case I would go with the single card and an SLI mobo.
However, if you don’t want to upgrade the graphics cards in the next 2 years, I would get two 7900’s now. That should run every current game and the ones released over the next 2 years at 1680x1050 with decent settings.
As far as the PCIe bus is concerned, while they do make systems that support full PCIe16 on both slots, it is NOT NECESSARY!! (well, not for graphics cards) Numerous studies have proven that graphics cards don’t even come close to utilizing the bandwidth of even a PCIe8X slot.
I want dual 16 slots because I plan on going with a RAM drive eventually once they are released. That is one device that can use all the bandwidth it can get (my fantasy is a system where my fav game loads levels instantly).
Anyway, one option would be to get the SLI mobo now, but only purchase one card (After all, moving to an SLI mobo doesn’t cost that much). Later on you can get a second card or use that other 16X slot for something else that doesn’t exist right now.
Either way, I think you should get the SLI mobo. The real decision is whether or not to purchase the additional card right now.
SLi is for those who have gigantic monitors and latest games and want to run it at the monitors native resolution... if you're still playing with mom & pops 17" CRT, then don't worry about SLi. :cool:
tru dat :)
-=ABUSIVE-69=- said:
Awesome sig!!
Arch... I suggest that you do get the SLi. I doubt it's going away anytime soon and your monitor is pretty big, although if you're going to be building a new system... $2000 is a lot to spend.. what all is that going to include?
Asian Dub Foundation said:
1 7900GT will be enough for ur monitor
not for oblivion. I just installed it yesterday and it crawled until I realized thar I had forgotten to enable SLI with the new nvidia beta drivers. with SLI enabled it is playable, but otherwise 1680x1050 at ultra quality is too slow.
noobtech said:
Awesome sig!!
The rest of the system is shaping up to be the following. I've already revised the list a couple times already so it might change:
EPoX EP-9NPA+SLI
AMD Athlon 64 X2 4400+ Toledo
2gig OCZ PC3200 (2x1gig) 2-3-2-5
BFG 7900GT OC PCIe (don't know, might be 1, might be 2)
Soundblaster Audigy2 ZS (carry over from old PC)
WD 150gig Raptor
Antec TruePower II 550 SLI ATX PSU
Cooler Master Praetorian PAC-T01-E1 case
Dell 2005FPW monitor
I think I might go with the SLI. I don't upgrade my video card all that often as they tend to last a couple years. My last couple cards were, a Geforce3 Ti200, then a Raedon 9700 Pro, then a 6800GT. I tend to skip a couple generations between upgrades. A pair of 7900GTs should let me keep that trend up.
I'd still appreciate additional opinions / insights.
I have the same monitor as you, 21" trinitron and sli is well worth it. in fact, even tho this monitor can go to 2048x1536 at 200mhz, when i try to run f.e.a.r. over 16x12 i get an error message telling me i need more memory on my vid cards.so 2x7900gt cannot max your display out at very high qualities. i can play f.e.a.r. 16x12, everything maxed, except soft shadows, and when i test it i get 100% over 40fps. havent tried with soft shadows yet. the only cards scoring higher than mine in 3d05 and 06 are 7800gtx 512 sli, and not even all of them and a couple 1900xtx cf. so you can definitely have the best sli or cf rig, and todays games will still outrun them on a high res display.
you might want to consider the evga superclocks at 550/1580, mine easily do 580/1800 stock cooling. also, the g.skill 2gb pc4000 kit for about $100 less than the ocz on sale at newegg now
http://www.newegg.com/Product/Product.asp?Item=N82E16820231021
also, i found that my antec 550 trucontrol had a little trouble running 7800gt sli. ran 1 card great, tho. save yourself some more cash and get a 3800x2, new steppings are great overclockers, or a 165/170.
good luck
good luck
Yeah, if you do what he says you will save lots of money and still have equal performance after overclocking. ^_^
Why, did this topic become your monitor size? Listen, I have SLI; and a 17" monitor. Yeah, my max resolution is 1280x1024; but I would not change a thing. I am able with SLI to max out all the settings on just about any game and I will get over 60FPS(with two 7800GT). So, I would recommend whether using a big screen or little screen just get it; so you are future proof(well kind of) and you can play games how they are made to be played not based on your screen size. I highly recommend you get SLI or Crossfire because it is worth it trust me.
That is a crock of crap; I have played this game with SLI on. I maxed out the settings and it does just fine. It does not crawl at all. He makes it sound like you get two frames per second. My computer does 30-90 FPS on this game; slowest being riding the horse in a lush forest with dynamic lighting; even still it is not slow enough for it to look like a slideshow. Also, get your bloody screen sizes right; no one will take you seriously if you don't. 1600x1200
Also, I don't use the beta drivers because many times flaws appear; when they add new features. So, this maybe the problem, also.
noobtech said:
Awesome sig!!
thx, and like i said, unlike sli which only works with games that nvidia programs the drivers for, ati crossfire works with all games and apps. yeah, ok, the nvidia drivers support almost every game in existence right now but its worth mentioning
Thanks!
Always look at the upgrade path, an SLI MB is the best way to go. You can always add a second card later.
Thanks!
1900x1200 8xAA 16xAF yes, 1280x960 4x AA 8xaf no...
Actually no one's taking you seriously because he was correct. 1680x1050 is a widescreen. You have some reading to do, my friend.
:rolleyes:
If, that is, you accept from the outset that either 'later' will be not too far down the track or that you'll be purchasing that second card secondhand! Reality is, for most people anyway, that by the time the funds are available for the second card the thing will have gone out of production and be missing from store shelves.
Buying a better card straight up front, then later selling the thing to someone else and replacing it with a more powerful card, is always the 'best' course of action to take.
Some time back, when SLI was just getting established as a 'mature' technology and when Crossfire was still very much speculation, I wrote this article. Graphics card technology has moved along a bit since then, but the sentiments expressed about the usefulness of dual-card systems are still every bit as relevent.
I have an SLI system for my own personal use. There was one reason and one reason only that it was my choice of purchase. At the time I put together the system I did I was able to purchase two 6600GT cards more cheaply than I could obtain the 6800GT which basically represented their equivalent in a single card. Situation such as that are rare anomolies.
SLI is worth it (of course with big monitors and high res's ) but as far as performance increase, the best one that ive seen to date is in the 7900 series. Looking at those numbers, I actually see (for the most part) a double increase in FPS during games. Question to all here:
I have a XFX 7800GTX. Should I sell it and get a 7900GT (easier to OC and cheaper than current 7800GTX so I can SLI them later), SLI my current 7800GTX, or keep this and save up over the summer for 2 G80 cards while selling whichever card(s) I had at the moment then for more cash?
same situation im in; i sold one of my 7800gtx's cuz i thought i could get the 7900 superclocked but then went outta stock, so I'm now on 1x 7800gtx 256 for my desktop rig.
Thanks everyone for your replies! I've been doing some digging and I have two options currently available to me:
Going SLI (7900GT x 2), along with the complete system would be around $1930.
Skipping SLI and going with an ATI X1900XTX would be around $1805, less a $30 rebate (if it actually goes through) and we're down to $1785.
What would you do?
I would also go with the single card but I am not a fan of the whole SLI/Crossfire thing. The latest single card can deliver excellent performance in all but the highest resolutions, will run quieter, use less power, take up less of your PCI slots, and is cheaper to boot.
SLi\Crossfire is like dating the hottest girl in high school... Not having SLi\Crossfire is like the hottest girl not giving you the time of day. It's your choice. Better make it a good one! :p
Arch.. I think it was vanilla_guerilla and noobtech who touched on the subject of overall cost of the system that you want to build. He has a very valid point. You have $2000 dollars to work with.. Its always good if you can save a few dollars and keep the performance on the same level.
The system that you want to build has a x2 4400+ processor. Personally, I think thats a great processor. (http://www.newegg.com/Product/Product.asp?Item=N82E16819103546 ). The cost of this processor on Newegg today is $460 dollars. It can be overclocked to around 2.5ghz - 2.6ghz on average.
It was mentioned in an earlier post that you could save a few dollars by changing the processor to a x2 3800+. (http://www.newegg.com/Product/Product.asp?Item=N82E16819103562 ). The cost of this processor on Newegg today is $295 dollars. This processor can be overclocked roughly the same as the x2 4400+.. Certainly these two processors can be pushed even more with water cooling, etc.. I have my x2 3800+ OC'd to 2.55ghz on a simple zalman 120mm fan and some Mushkin Performance DDR500 memory (PC4000) ( http://www.newegg.com/Product/Product.asp?Item=N82E16820146397 ).. So, you can see, you can save around $165 dollars just on the processor.
As for SLi, I had only one eVGA 7800GTX 256mb card for a few months.. It was pretty fast but when I picked up a second 7800GTX, I must say, I was really impressed. True, my 19" LCD Monitor has a max (native) resolution of 1280x1024, but I could tell how much faster the frame rates were in benchmarking utilities and under heavy gaming like F.E.A.R., FarCry, etc.. I can't speak for the crossfire setup because I don't own ATI cards, but I would think the same principles apply. I would completely recommend an SLi setup if you like heavy gaming, a large monitor/high resolutions, "future-proofing" for the next few years, etc..
Just found the Sapphire X1900XTX. This is $100 less than the ATI card. Minus $50 for the Newegg combo discount I could get with the ATI card and this thing still comes in $35 less, even with the ATI rebate.
Now its the X1900XTX and the rest of the system for $1754. $200 less than the SLI system.
officer, thanks for the heads up. In the past I've bought the lesser CPU with intentions of overclocking to the same level as the higher priced CPUs. I've always come up short, or ended up spending extra money on heatsinks and other accessories to get me there. That being said, I'm trying to avoid that this time around by getting the 4400+, knowing it will perform at the level I want without any tinkering. If I can overclock it decently, great, it not, it won't be as big a deal.
2 x 7900GT, o/c them.
Opty 165 or 170 will o/c equal to or better than a 4400, run cooler, and probably faster clock for clock because of the added cache. (I just got my 170 for $372. OEM delivered from Monarch a couple weeks ago.)
Add a half-decent HSF and it's cheaper & better than the 4400. You won't need more than 2.4GHz for any game now and at that speed on an A64 you won't be CPU bottlenecked.
Don't skimp on the PSU. Get a name-brand unit with enough juice: 500W or greater from Hiper, Seasonic, OCZ, Antec, Fortron, etc.
bobrownik said:
neither sli or crossfire are worth the money in my opinion ,
Methinks that this is probably true.
The day that crossfire / SLI will truly become VERY cost efficient is when you can pair up cards that are cross generation. i.e. buy that 1900 XTX now and pair it up with a RD600 in CF when they come out. But...I have absolutely no technical knowledge of this stuff so I'm sure that there is some reason that this would be an impossibility. :rolleyes: Ah well...
I want to buy a new Videocard(s).
I have an SLI MB (see sig).
I am stuck between buying one of the following:
Sapphire X1900XT
eVGA 7900GT OC x 2 SLI
eVGA 7900GTX
I have a X850XT-PE and I love it, so the X1900XT is a nice choice in my book.
I can get SLI 7900GT's and be ridnging the smooth wave for a while.
Or I can get a single 7900GTX maybe later when I have some playing money again, buy a second one.
so, now, sli or crossfire, for me crossfire because it works with all apps without having to have the programmers program into the latest drivers what apps it can work with like sli
In time, Crossfire will succeed SLi... :D
