Scream And Fly
- Nov 27, 2005
Well, what I mean is, is SLI less stable than a single card solution? If system stability is my first priority, should I be running a single card?
Greg
Greg
UltimaParadox said:Of course it will be less stable when it comes down to numbers, since you are adding another piece of hardware, thats just facts.
However I wouldn't base my purchasing decision based on the stability of SLi as it will probablly vary from card to card. Of course when you buy their product is should be stable at stock.
heatlesssun said:I would say that what you're talking about is fault tolerance vs stability. If you have two GPU's the chances have just doubled that you'll a video card failure as you now have two that could fail.
