Hi Tony,
If you are doing so, i hope you revert back to RV02/FT02 designs.
FT02 thread have 3700 posts and 1million view!
FT05 no thread in sight. I dont think the core buyers are buying it. Hence defeats the idea that a cheaper/smaller casing will sell more.
FT03 - weird choice
RV03 - regressed design.
FT04/RV04 - lazy design
FT05/RV05 - failed attempt to tap the cheaper crowd
I plead FT06/RV06 to be like FT02, big case, 3xAP181, same window side.
I seen mods of FT02, i think it works as well for WC setup, with 3x180mm rads on the AP fans! And the top 120mm rad is possible. Plentiful of cooling OC CPU/GPU imo.
But you need cut to three 5.25" bays. 1 for optical drive, 2 for potential bay res.
Move the HDD cage upwards to accommodate rad mounting
Move the motherboard tray higher so fans/rad can slide in/out easier.
Increase the back area for cable routing..
Profit.
But you guys keep making bad decisions.
You can cut down to from 200 to 150 and from 150 to 100. But who to say the cheap buyers wont look for 100 to 50 cases?
You need to tap back the 1million viewers FT02/RV02, core PC dudes are willing to spend for good value stuffs.
FT03 - weird choice
Profit.
