nekrosoft13
- Jan 4, 2005
so what do you think will happen to SATA express, seems like no one is making drives.
sata express leaves you minus 2 sata ports
m. 2 leaves you plus 1
you do the math
(M.2, SATA Express, and SATA3 4/5 connectors can only be used one at a time. The SATA3 4/5 connectors will become unavailable when an M.2 SSD is installed.)
* The SATA5 and SATA6 ports will be unavailable when installing a module in the M.2 port.
you do the math
that might depend per board
on a lot of the z97 chips m.2 disables two sata ports
Gigabyte
MSI
m.2 can take away PCI-e lanes that would otherwise be used for SATA, depending on how the motherboard is designed.
This is a good article on m.2
http://compreviews.about.com/od/storage/fl/What-Is-M2.htm
There is more than one thing wrong with that link.
Yes you can boot from M.2, but not just as easy (yet) as SATA SSD.
Booting from PCIe SSD's that don't have a boot ROM or how it's called, need a supporting motherboard (actually, UEFI) Windows 8, modern Linux or Mac. For Windows 7, drivers on install and a boot ROM are needed as far as I know. NVMe support started from Windows 8.1 I believe.
