Hi all!
I am trying to put together a nicely overclocked C2D system and still stick to a budget. However, I intend to run my ram at 500mhz.
Finding a mothermoard able to reach 500mhz fsb stable that fits my budget (~$170) has been quite tough and I am about to give up on my search. Therefore I ask you:
What is the performance difference between running ram at 500mhz (500x1) at 1:1 and running it at 4:5 (400x1.25)?
Consider same clock speeds for the CPU, since I'm probably getting a e4300 and juggling with it's multi (9x-7x)
Thanks,
Horacio
Thanks,
Horacio
