I have a system in a Antec Sonata II case powered by a Antec SmartPower 2.0 450W, For the past week the system will not power up from the front mounted switch, BUT if I unplug the power in cord or turn off the main PSU switch at the back for about 15 sec and then replug or turn the switch back on, all works well and I can power on from the front switch, Is this likely a PSU prob? and if so can I do anything other than replace PSU?
