Opteration
- Jan 2, 2006
I plan to buy the OCZ phase, can that unit hold up to phase change, and can i run my processor on phase 24/7 without hurting something?
You are very funny and clearly don't understand the entent of this OCZ phase unit.Erasmus354 said:You place a heater on the back of the motherboard behind the CPU to prevent condensation.
Hydrogenlockheed2266 said:Could someone explain what phase cooling accualy is? is it using liquid hitrigen to cool your CPU?
The claim is an extra 20 bux a month max.Volkum said:How much power do these units typically draw?
R1ckCa1n said:You are very funny and clearly don't understand the entent of this OCZ phase unit.
If the block is installed correctly you will not have to worry about condensation. This unit is being made as a 24/7 unit. Only down side is it will only run one head meaning you must either buy two for CPU/GPU or watercool the balance.
You can keep your card on air if you wish.chambersc said:aww damn, so your saying that if im going from AIR to the OCZ setup that's coming out soon, i'll need to WC my GPU? i don't get it. why?
After all the stuff I read and picture I've seen, I didn't know they used heaters...Visable-assassin said:Cant speak for the OCZ unit but the prometia used a heater on the back of the mobo and one around the socket and i think the vapochills are the same way.
Just gotta be a little creativethunderstruck! said:One head on a single stage is the standard. Also, you can't just buy another one for you GPU. Good luck mounting it.
