Is orthos a good overclock stability tester?
Dutt1113
Is orthos a good overclock stability tester? I see that it automatically stresses both cores. How long should I run it for a stable overclock? Should I use a different program? By the way, I'm overclocking an e6600 if that makes a difference.
Orthos should be good for dual core chips. Should run it 8-12 hrs for 24/7 uses.
I don't know if it makes a difference but I'm using orthos beta v41.110.18
