Carlosinfl
Loves the juice
- Sep 25, 2002
I am having problems finding room for a 2nd 120mm BIP in my case so I was wondering how bad would my system be if I just had one single 120mm BIP in the setup w/ no over clocking at all?
- Intel Core 2 Duo E600 (stock 2.4 GHz) - EK-Wave 775 CPU Water Block
- eVGA Ge-Force 8800GTS 320MB - EK Full Coverage GeForce 8800 GTS Water Block
- Swiftech MCP655
All this is flowing through 1/2" ID Clear Tubing.
Do you think I will have a problem or is it worth the touble squeezing in the 2nd BIP radiator into the setup somehow?
Thanks for any info!
- Swiftech MCP655
