is my voltage too low?
endrbud
system in sig. I've had this psu for about a year. Opinions?
thanks
something odd about the +12 And -12 results....Someone who know more than me please reply.
the negative volts you don't need to worry about but the 5v and 12v are way low, also what cpu are you running that is using such a high VCore
No offense but i wouldn't trust that monitoring software, nor any other actually. They are notorious for being inaccurate (so is the bios for that matter). The easiest soho solution for monitoring voltages and fluctuations is with a multimeter. Hook it to a molex and test your rig starting from boot-up and follow through with serious stress testing.
If your rig is otherwise stable i wouldn't worry about it (trash that junk soyo software too ! ;) )
thx for the replys. not trying to be anal but.. "that junk soltek software..." :D
