is my system fubar
DrDoU
turn system on get no output to monitor
i have tried resitting the cpu and video card,using one stick or ram then swapping.
using barebones system
swaped cpu coolers
video card in different pci slots
do not have an extra video card to test with
thats all i can think of
system has not been overclocked
system fans all work so i at least have power to motherboard
system is in sig and ideas,help at this stage is greatly appreciated thanks.:(
My first guess would be a dead video card.... but if you don't have another to test with it's going to be difficult to determine rather that's the case or not...
Can you check your PSU voltages? That would be my second guess.... but I really think it's probably going to be your card...
that is the direction i have been leanning.i have made the jump from agp to pci-e and it is bummer to have a pile of agp cards lying around and can not use any.i am going to try the sapphire site to see if i can get any addional info before rma
that is the direction i have been leanning.i have made the jump from agp to pci and it is bummer to have a pile of agp cards lying around and can not use any.
You mean PCI-Express don't you.
that is the direction i have been leanning.i have made the jump from agp to pci and it is bummer to have a pile of agp cards lying around and can not use any.i am going to try the sapphire site to see if i can get any addional info before rma
My wife had to rma her Sapphire X1950gt about a week after she got it..... really the big reason I'm thinking your card is the issue... she had the exact same symptoms as your describing...
pull the ram out and try to POST. Listen for error beeps. If there are none, pull the vidcard out and try to POST. Listen for error beeps. If there are none, make sure a system speaker is plugged in, lol. If a speaker is plugged in and no beeps without vidcard or RAM, its probably your CPU or board. If you do hear beeps, try a spare card/dimm. If you don't have one, borrow one from a friend or work.
you were right the video card is bad.i took it and the power supply to the local pc guru and had them tested the video card tiuned up as the bad component.i also lost my dvd burner which had me thinking i had a power supply going bad
thanks to all for the help
thats why i keep around an even older PCI video card!
PCI video?! Oh wait, I have a few of those for testing purposes too. :)
I also like to keep around motherboards and cpu's for testing. You never know when somebody will ask you to take a look at an old p3 or socket a/754/603, etc. hehe
finally put a new video card in and got the same result no power to monitor.i have had the power supply and the cpu tested and they are all right.but now i have a new problem,the dvd gets no power unless i disconnect the ribbon cable then i can get the tray door to open and i have the same results with the harddrives.as best as i can tell they are not spinning up.i am starting to seriously look at the motherboard.does any one have any ideas.i am wondering about newegg parts and service for the future.
