Is my SMP setup right?
ICE_9
Long time folder, need some reteaching.
I have an i7 870 at 3.1GHz (no overclock) I have been using the FAH GPU tracker to run both my GPU and SMP clients. I haven't had -bigadv turned on and don't have -advmethods turned on. Are my settings now correct for better PPD? I already have a passkey setup. I am getting about 250K/month currently using just 6 threads of the 8 possible. Suggestions?
Thanks!
Sorry, can't hit hardfolding to get my sig stuff so this one will have to do for today.
sigimage.php
It sounds like you are in the right ballpark - 8K - 9K ppd. Install HFM.net to see what it is really doing per day. Just out of curiosity, why 6 threads instead of 7 or 8?
OP also has a GPU.....i would th ink that the PPD is a bit low for both a GPU and a i7 870...
OP what GPU are you running ?
Is it an ATI GPU? If so, you should probably stop folding on it and just use your CPU.
This.......
Until they release a more substantial client specifially for ATI cards
8800gs getting about 3k. I use 6 thread so that the computer is still responsive to my liking.
