Is my ram running correctly?
yes it is running "right". Many , if not all motherboards , when they detect ddr800 will default to 5-5-5-15 for the ram timings. You must manually go into the bios and change the timings to 4-4-4-15. the 2:3 ratio is correct. You can try 4-4-4-12
