I'm using these...
Ripjaw's F3-12800CL9D-4GBRL - http://www.gskill.com/products.php?index=222
The motherboard I'm using is not listed under its "Qualified Motherboards List". Mobo is GIGABYTE GA-P55M-UD2 - http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=3165
Could this be one of the reasons as to why my computer keeps locking up? [no BSOD though]
update :
- memtest ran fine
- all speeds are properly set in BIOS for ram and CPU
I tried to run the computer by removing one memory stick and only leaving one 2gb ram to test each ram individually.
however, when I power up my pc w/ only 1 ramstick, it doesn't boot! lights just come on on the mobo and it's like as if there's no feed to monitor. is this normal?
update :
- memtest ran fine
