Is my pump dying?
tory
Alright so lastnight i realized me temps on my cpu loop were really high I looked at my res and there was what seemed to be no flow...
So i tore down the loop and set up a simple Res > Pump > Block > Res just to see what flow was like... well i got it setup plugged it in to my machine and even with 2ft of tubing and the only thing restricting flow is my xt block my res water was still calm. So there is flow but not enough.
Pump is an MCP655
Is it on its last leg?
The answer seems to be yes. It should have 5-year warranty though.
I got a mcp655 that all I have needed to do is biannually pull it apart and scrub every surface of it down. Running great 8 years later with minimal wear. You should do that. Also, modern cpu block design makes really good filters.. Pull cpu block apart and clean that too it could be gummed up
