Ok, well I have a cheaper 600w PSU with two 12v PCI-E lines, one runs at 18a and the other at 20a. untill recently I've always had an 8800GTS OC'd to 650/1008. Now I have an 8800GTX and at stock it runs fine, but since i overclocked it to my sig specs I thoguht it was working fine, untill I was playing hellgate London and started noticing white dots on everything.
When I opened rivatuner the card was only at 55c (I tested with ATI tool before and min load is 50c max is 63c stable) but my card was constantly downclocking back to stock then jumping back up to the OC.
Can the card not getting enough juice cause wierd artifacts? I'm pretty sure that it's downclocking back to stock is lack of power, but can artifacts be caused by lack of power?
This is the PSU I use
http://www.tigerdirect.ca/applications/searchtools/item-detailsInactive.asp?Sku=ULT31848
This card should atleats be able to run a GTX at stock right? It ran that GTS at the OC level no problem. If it will hold for 2 more months I'll ask the wife to get me a new PSU for x-mas lol.
