aeonrevolution
- Aug 30, 2004
Ok so I cannot find the exact output for my psu first off. It is the one in the Dimensions 4600. Right now everything is running fine and here is what I have connected.
1x40gb harddrive
1x9800 pro 128mb
1x40 speed burner
1x ethernet card?
Then of course the ram and processor. Should I be able to put in another hard-drive of about 120gb? If need be I will probably just swap hard-drives if I cannot use both at the same time.
Also on a side note, what is the difference with whether a hd is SATA or not? I found a western digital at newegg that is 120gb, one that is SATA and one that is not with a $15 prices difference or so. The connections seem the same.
1x40gb harddrive
1x9800 pro 128mb
1x40 speed burner
1x ethernet card?
