Is my PSU enough for my future setup?
dorky82
Right now I'm using rockfish 700w. I read its really a 550w psu.
Will this psu allow me to run
amd 950
with
4850 in crossfire?
Right now I'm running kuma with only one harddrive. Shopping for budget 4850 and another 4850 in the future. No cd/dvd drive.
Thanks
It could probably handle it, but it's a really crappy PSU and I wouldn't recommend it.
I'd use a 550W PSU with 1x4850 but not 2, a decent 550W is about the minimum I recommend for 1 4850 card + high wattage CPU .
I also would never use such a low grade PSU.
Save yourself the heartache and get a good PSU that can cope easily with your load (heh, thats not a porn reference!).
ie run less than 60% of the PSU's max under load.
