These are my specs:
DFI Lan Party NFII Ultra B
- 4 firewire ports
- 8 USB ports
- dual ethernet
AMD Mobile running a 2.6ghz @ 1.8 volts (even at stock speeds it crashes)
1GB of OCZ gold PC3200 running at 3.3 volts
Radeon 9600 Pro 128 meg with a zalman heatsink - AGP
Radeon 7000 64 megs - PCI (for secondary monitor
160GB Seagate Hard drive - IDE
Lite-on DVDRW - IDE
Audigy X-gamer sound card
flash card reader - SD, CF, MMC, etc...
56k modem
floppy drives
2 80mm fans
2 92mm fans
Now, my powersupply is a Zalman 400 watt (ZM400A-APF) http://www.zalman.co.kr/eng/product/view.asp?idx=3&code=015
the thing that worries me is this, the 12v only has 15 amps is this enough?
through hardware doctor, my +12v status varies between 11.40 and 11.52. Could this be the problem of my crash? I don't have a lot of money, but if I need to, I will have to buy another PSU. I need one that is near silent through.
My system crashes randomly, and I get the BSOD on the monitor that has the AGP card.
Thanks
- 4 firewire ports
- 8 USB ports
- dual ethernet
Lite-on DVDRW - IDE
56k modem
floppy drives
2 80mm fans
2 92mm fans
Thanks
