Chrissicom
- Jul 7, 2005
Ok, I have an Antec 350W Phantom passive power supply. The temperature sensor directly attached to the fins reads no more than 40 °C on full load for a few hours. I will upgrade my system and I want to know if my power supply is still enough.
My old system (uses 240 Watts at full load and 200 Watts when I turn the computer on)
Pentium 4 3 GHz, 800 Mhz FSB (passive cooling)
MSI Neo FIS2R i875P (northbridge fan unmounted, ugly led thing)
2x Corsair XMS CL2 512 MB
2x Maxtor DiamondMax 9 120 GB SATA
2x Maxtor DimaondMax 10 200 GB SATA
1x Maxtor DiamondMax 10 300 GB IDE
Hercules Radeon 9700 Pro (passive cooling)
Creative SoundBlaster Audigy 2 ZS
Surecom Wirelass LAN PCI Adapter
8 USB Devices connected (i.e. I make use of all USB ports with printer, bluetooth hub, scanner, wireless hub for keyboard, camera, video encoding device etc.)
The system is cooled by 3 120 mm Noiseblocker fans and 2 80 mm Noiseblocker fans which are all pretty much noiseless
NEC ND5100C (not sure about the tile)
Pioneer DVD-RAM Recorder (v110)
Here's the system I will have and I wanna know if you think the PSU is still enough (in my opinion it should still do its job)
Athlon X2 3800+ (probably with XP-120 and 120mm Noiseblocker fan)
Asus A8N-SLI Premium
2x DiamondMax 10 200 GB SATA
1x DiamondMax 10 300 GB IDE
Asus Extreme N7800GT
Same WLAN and USB stuff
Same case (CoolerMaster Stacker) with the same fans
The AMD CPU requires 89 Watts that's about the same my P4 requires. I removed two 120 GB HDDs and replaced the 9700 Pro by a 7800 GT which will require more power. But I still have 100 Watts left on the PSU to be used and considering that it has its best effiency on 85% usage I think it should easily handle the new system, anyway what do you think?
