Is my power supply dying?
McDork
I have an OCZ Gamextreme 700 that is about 2 1/2 years old. I was running an AMD 4800+ at 3.0 stably (with Crucial Ballistic DDR 500) for two years. Recently the PC started blue screening, locking up, crashing, and in games the images started fracturing (3d stability?). I backed off on the overclocks on the CPU, and the graphics card (8800GTS/512). I ran memtest, and the memory checked out fine. The computer is running good now, but I would like to get my overclocks back. Is the CPU dying or is the problem with the power supply? Thanks.
Your overclock probably isn't good anymore. I mean this - if you tested for max HTT, max clock all over again, I imagine your values probably have changed (i.e. everything needing a small bump). Could be IMC degradation, chipset/mobo degradation, who knows. But yeah if you go back to stock and can load it for hours on end with no BSODs, there's your answer.
I agree with Mav451 and it can also be caused by dust build up, reduction in PC case airflow or warmer ambient temp.
If the problem starts again within a few months after a small decrease in clock speed (and there is no extra dust build up...) then the PSU may be on a slow decline.
Thanks for the help. I did clean things out with compressed air before I clocked things back, and it didn't seem to help with the crashes. It didn't seem to be a problem w/heat as I was monitoring the temps, and they never got that high. If I bump the voltage up a bit will it accelerate the degradation of the MB or the CPU? The MB is an Asus A8N-Sli Deluxe, and is 4+ years old.
Raising the voltage could cause your CPU to degrade more if it's already on its way out. I suggest you just keep things at stock for the time being and see whether or not you encounter any problems.
i thought my psu was dying, strapped a 120mm fan to the back of it and it seemed to have sorted itself out.
could be heat
You have a spare psu you could use, to see if you get the same prob? Steal one from a friend for awhile or something? ;):D
You need external equipment to test a PSU reliably.
Basic testing can be performed with a multimeter to see how much the voltage drops when under load.
To do this, measure 12V (Yellow to black) on the 4 or 8 pin motherboard power connector.
Get its voltage at idle and then again when running an intense game.
Report both back.
You can do a less reliable method of this test but it might still indicate the same problem:
The motherboard will come with a monitoring util.
Get it to log the voltages while you game so you can see how 12V fluctuates.
Report the results.
Note any other voltages changes as well while you are at it.
12V is critical as it is the most heavily used voltage for the CPU and graphics cards and therefore has to provide high current.
This is the most likely voltage rail to have problems.
Many PSUs have more than one 12V rail, the above is testing the CPU voltage rail.
You can do the same test with a multimeter on the power lead to your graphics card.
The reason I think the PSU is getting hot is because as it ages, a PSU becomes less efficient.
It doesnt suddenly start to use more power from the wall though, it drops its maximum output to the PC.
This drop in power output doesnt reduce power usage, it is converted to heat in the PSU, hence the drop in efficiency.
Its when its ability to power the PC drops low enough (the PSU gets warmer too) that you start to see problems from basic aging.
There are many other modes of failure for a PSU and perhaps some of them are occurring as well, but it may not be necessary to go that far.
I would say it's not likely that your PSU causing the problem. The only way to tell is to do what is suggested above and change out your PSU for a known good one. Measuring voltage drops and the like will not tell you if your PSU has changed overtime, or whether any changes would effect your overclock. It will only tell your PSU what it is doing today, which could be the about same as it was doing 2.5 years ago.
Running extra voltage and overclocking a CPU and motherboard will have an effect over time. In real wold use, lowering your overclock a bit isn't going to be noticed.
