is my mouse dying or what?
Dome
i have an mx700, had it about 2.5 years now i think and i've never had problems w/ it til recently. sometimes it'll start skipping, like lagging, and sometimes clicks don't register, and sometimes they'll drag even if i've let off the button. it doesn't say its low on batteries cuz i charge it everynight, any ideas on what it might be?
probabily just getting old and wearing out.... that or there is some lint or somthing inside.
I had problems with lint in the laser cubby hole on the outside. Make sure there aren't any debris covering the laser, but power off first. Lasers :eek: hurt
You watch too much star wars. Do you realize EXACTLY HOW concentrated the lazer has to be before it starts doing damage to the skin?
Try a new set of rechargable batteries, they don't last forever. I had the same problem with mine
tey using usb/ps2 the opposite of what youre using now. and i doubt its just somthing covering the laser vamp he said that it wasnt picking up some of his clicks....
In all honesty, I think it's coming to the end of it's life. I bought a Logitech mouse, and somewhere in the documentation it had a sort of "expectancy" information that its guaranteed to last good up until a certain "distance" of usage. I think it was measured in miles, or something, but don't hold me to that, but yeah, I think it's traveled it's final "mile". Time to retire it.
It's not a laser, its an LED. You're not going to be able to hurt yourself with it, it's as harmful as a bright light.
I don't know about bright LED life, but I think 2 1/2 years of use is not in excess of a regular LED life. I'd check the CMOS chip (the part that detects light) for debris. Use a lint free cloth, or delicate brush (like a small, clean, soft paintbrush) to remove any debris.
But the LED is constantly turning on and off, etc, so it could get worn out easier than if it just stood there and did nothing all the time, like a LED in a case fan, or something.
im talking about the eyes. very sensitive spot, correct?
