Is my monitor's brightness broken?
lobski
W3000H-BN is supposably "370 cd/m2 Brightness" yet when I validate the brightness under Basiccolour, the highest it goes up to is 200cdm/2. I turned the brightness up to the max on my monitor.
What do you guys think?
I assume you can see brightness change while you hold the button down and you hold it down for a long time to ensure it reaches max. (no feedback, no OSD controls suck). Also disable dynamic contrast if on.
Did you check it after it fully warmed up. My 30" took at least 20 minutes to reach full brightness. I would wait at least 30 minutes before any measurement or calibration. I remember getting it and thinking. Hey it goes low enough and once it fully warmed up I had on zero and it was still too bright. These are the slowest warming panels out there.
If you have any calibration done, you need to remove it. Calibrating will reduce the brightness of your monitor.
Likewise, any settings you may have messed with on your graphics card.
Do all the above and it should pass 300cd/m2.
