I've attempted to troubleshoot my box's instability issue into oblivion, but am still having issues. Anyone have any suggestions outside of what I've covered below, or should I just assume that it's time to trash'r?
Overall Problem
PC bluescreens in windows, but also crashes in Ubuntu
Case History
3-4 months ago:
USB 2.0 hub connected to mobo's onboard USB 2.0 port all of a sudden only worked as a USB 1.0 hub. Thought that it was due to a faulty USB hub and I replaced it. Replaced hub now has also 'downgraded' to a USB 1.0 hub.
1 month ago:
PC started bluescreening in Windows. Took this as a sign to start experimenting with a totally free software PC and installed Ubuntu. Worked OK at first, but then even Linux started crashing on boot (I think it's a greenscreen).
Recently:
PC got to a point where I had to hit the factory default settings button on the mobo in order for it to even POST. Turned on Windows and everything was A-OK. Flipped on Youtube to check something out, but there was no sound... quickly realized that the factory default settings disable the onboard soundcard (Creative Audigy).
Reset, enabled onboard soundcard, booted into Windows. PC then either bluescreened with a Machine_Exception_Error (or something similar) during WinXP boot, or right after login. Resetting and going into Ubuntu also crashed the machine.
Installed an independent Audigy card, disabled onboard sound, and booted into Windows. Everything OK. Started installing drivers for soundcard, and the machine crashed during install.
Swapped Audigy card for an Asus Xonar thinking that the driver install somehow attempted to access the onboard soundcard, thus causing the bluescreen. Boot, install driver, sound achieved! Assumed that the daemons had been defeated.
A day later, machine started crashing again with Machine_Exception bluescreens.
Fruitless Troubleshooting So Far
Outstanding Symptoms
Other Details
At the moment, the next thing that I might look into is the southbridge heatsink since it's always DAMN hot. I've not dealt with a problem like that before, but my head has put together: If the southbridge is overheating, that would explain why the onboard components (USB, sound, etc) seem to be malfunctioning.
Planning on doing a full upgrade in the fall, but was hoping to fix these problems up so that I can put together a media server or donate the thing to charity.
Any suggestions welcome!
Overall Problem
Case History
3-4 months ago:
1 month ago:
Recently:
- Ran a memTest overnight. No problems detected.
- Various soundcard disabling and replacement, as mentioned above
- Disconnecting everything except the OS HDD and video card
- Using Ubuntu instead of Windows
- South bridge heatsink (I think it's the southbridge, at least) seems to be always BLAZING hot
- Plugging in any USB device into any USB port knocks my USB wireless adapter temporarily offline (comes back up after a minute)
- Crashes occur during Flash videos, games, or even just leaving the computer alone (I'll wake up to see a bluescreen)
- Video card seems to be pushing a lot of hot air, but sensors tell me that it's running at a nominal heat level
- After a crash, restarting immediately usually results in an instant crash. Leaving the box off for 5-10 minutes typically allows me to boot up without a crash again, but not always
Other Details
- Gear is about 3-4 years old at this point
[*]AMD 4600+ CPU, Socket 939
[*]Zalman 9900 heatsink (cranked to max always)
[*]Geforce 9800 GT
[*]MSI K8N Diamond Plus Mobo
- Top of PC near the powersupply (top mounted) seems warm, but not hot
