is my LCD dying??? pics.
felony
Hey guys.
Looking for your input here. These are some screenies from my 26" oloevia LCD plugged in via VGA over a KVM switch. I just noticed these problems after loading up this flight in fs9 so it will be a while until i try and old system image.. but anyway, what do you think?
Images are in order. First image is just an opened windows explorer w/o moving the window around. Second image is dragging the window around. 3rd image is closing the window and all is back to normal (though the glitch remains)..
Any ideas?
Thanks in advance.
Dan
Not sure why but it switching my video to 16bit fixed the problem. Not sure why, but my other video source on the KVM is displaying @ 32bit w/o a problem?
If we can see them then it's not your monitor. It's definitely your Graphics card. Go get a new one or RMA your old one.
The good news is that your LCD isn't dying.. if it was the LCD creating the glitches then you wouldn't be able to use windows to take screenshots of the glitches.
The bad news is that it's either your KVM switch or your graphics card that is causing the issue. To determine the source of the issue I would suggest switching back to 32bit color and cause the glitches to occur. When this happens disconnect the KVM switch and connect your LCD directly to the PC. If glitches continue then it's either your video card or your drivers. If the glitches disappear then it is your KVM switch.
