Is my hardware setup right?
I don't know if I'm using my setup to its potential. I don't want to OC yet but I want to make sure I'm squeezing everything I can out of my current setup and using the right settings etc. Do those clocks seem right for a 5900 Ultra? Any glaring issues?
Thanks,
B5
System Configuration
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer
Mobo Model MS-7025
AGP Rates (Current/Available) 0x /
CPU AMD Athlon(tm) 64 2210 MHz
FSB 200 MHz
Memory 1024 MB
Display Information
Graphics Chipset NVIDIA GeForce FX 5900 Ultra
Driver Name MSI MS-StarForce GeForce FX 5900 Ultra (NVIDIA GeForce FX 5900 Ultra)
Driver Version 6.1.7.7
Driver Status Non WHQL - Not FM Approved
Video Memory 256 MB
Core Clock 301 MHz
Memory Clock 851 MHz
Sound Information
Sound Adapter Driver Name Realtek AC97 Audio
Sound Adapter Driver Version 5.10.0.5620
Benchmark Settings
Program Version 3DMark03 Revision 4 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 6126 3DMarks
CPU Score 872 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 202.3 fps
GT2 - Battle of Proxycon 42.6 fps
GT3 - Troll's Lair 34.7 fps
GT4 - Mother Nature 37.3 fps
CPU Tests
CPU Test 1 99.0 fps
CPU Test 2 15.2 fps
Feature Tests
Fill Rate (Single-Texturing) 1479.8 MTexels/s
Fill Rate (Multi-Texturing) 3206.7 MTexels/s
Vertex Shader 17.8 fps
Pixel Shader 2.0 49.5 fps
Ragtroll 20.9 fps
Sound Tests
No sounds 68.0 fps
24 sounds 55.7 fps
60 sounds Not Supported
