Oil from the fan bearings would never show up on the tip of a single fan blade without showing up on the paper on the hub. Whatever lubrication is in the fan bearings are located in the fan's hub area. If it came from the bearings there would be dark streaks from the hub outward.
You may have some fluid inside your PC, but it didn't come from the fan bearings.
Looking at the amount of yellow gunk on the paper towel that you have the fan sitting on, to me that looks far too much gunk for it to come out of a fan.
Do you not have anything else in your pc that is that colour ?
Odd question, but what did it smell like?
