Dec 29, 2007 #1 F fantomau 2[H]4U Joined Aug 25, 2007 Messages 3,367 With CoreTemp, The revision says G0, CPUID is 0x6FB But with CPU-Z, It says Stepping B, Revision G0 And with the Intel Processor ID util it says CPU Stepping B, Revision B3.
Dec 29, 2007 #2 S spikeyone Weaksauce Joined Oct 13, 2007 Messages 113 I'm pretty sure that the E6750 initially came out at the same time as the G0 stepping came out for the other chips, so the E6750 is only available in G0. Some googling seems to support this.
Dec 29, 2007 #3 WhiteZero 2[H]4U Joined Oct 21, 2004 Messages 3,638 E6750 only comes in G0... unless Intel's own site is wrong: http://processorfinder.intel.com/List.aspx?ProcFam=2558&sSpec=&OrdCode=
Dec 30, 2007 #5 X Xaijin Limp Gawd Joined Jun 15, 2007 Messages 181 Dont worry about it. They only come in G0's. Sometimes software gives faulty readings. I've seen 16 ghz cpu readings or other crazy stuff.
