Is my current PSU enough ?
Juic3
Hi, Im using an Enermax Noisetaker 485w.
http://www.newegg.com/Product/Product.asp?Item=N82E16817103457
+3.3V@32A, +5V@32A, +12V1@18A, +12V2@18A, -12V@0.8A, +5VSB@2.5A
Im currently running this full setup:
Abit KN8 Sli
BBA X1800XL ... gpucore at 1.75V and clocks at 605/650.
AMD Opteron 165.... Vcore 1.5V at 2.6Ghz
2GB (2x1GB) Gskill DDR500 HZ at 236.5Mhz
160 GB Seagate SATAII
Nec 3520 DVD Burner
SB Audigy 2
Scythe Ninja with 120mm Scythe 1200rpm fan.
2x120mm 1200rpm Scythe fans connected to motherboard headers.
Now according to the this psu calculator:
http://www.extreme.outervision.com/
I need 565w ?!?! :eek:
And now Im gonna get an X1800XT and its telling me 615W :eek:
http://www.newegg.com/Product/Product.asp?Item=N82E16817709004
+3.3V@28A, +5V@36A, +12V1@20A, +12V2@18A, +12V2@0.8A, +5VSB@2.5A
Lower 3.3 hmmm.
Would something like this 550w model work way better for me ?
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
TruepowerII with 120mm fan ?
I dont wanna go over $100 for this :p
Im jumping the gun on the X1800XT/vf700-cu combo w/ the new PSU(if needed), today so any help would come in handy :D
Ok I ended up getting just the card and zalman, Ill go back to stock vcore until I sort out which PSU to get.
