With all settings at default in the BIOS, it shows the CPU temperature as around 50 degrees. However, because I've been having a problem with random rebooting, I tried increasing the memory voltage by one level. Now the BIOS says that the CPU is 79 degrees...which would obviously explain rebooting issues!
Which one of these numbers should I trust, though? I have a Soltek QBic paired up with an Athlon64 3400+, if that helps anyone.
Thanks for reading!
Tim
Thanks for reading!
Tim
