Captain Colonoscopy
- Feb 19, 2004
So, I'm getting these alerts about every day from my WHS telling me that it is rebuilding or initializing all the time. Here is the stuff from the log. I'm starting to get worried about my data. I have all my pictures and music backed up off-site using iDrive but I don't have a local backup yet, was going to work on that this week as I have a few spare 750GB drives. Anyway, is this the controller spitting out errors or do I have a bad HDD that I need to replace. Looks like it's the same drive every time but when I check the drive status in the management utility it shows all drives as good. Here is the log:
Any insight would be appreciated. Thanks!
18:22:03 Mon 19-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 18:21:41 Mon 19-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 18:21:41 Mon 19-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 18:20:44 Mon 19-Oct-2009 Controller 2
Unit 0 Striped with Parity 64K (RAID 5)
. 17:37:54 Fri 16-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 17:37:52 Fri 16-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 17:37:52 Fri 16-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 17:36:56 Fri 16-Oct-2009 Controller 2
. 01:49:56 Fri 16-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 01:49:54 Fri 16-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 01:49:53 Fri 16-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 01:48:57 Fri 16-Oct-2009 Controller 2
. 15:21:46 Thu 15-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 15:21:40 Thu 15-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 15:21:40 Thu 15-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 15:20:43 Thu 15-Oct-2009 Controller 2
. 01:36:16 Thu 15-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 01:36:16 Thu 15-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 01:35:20 Thu 15-Oct-2009 Controller 2
. 09:16:30 Wed 14-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 09:16:28 Wed 14-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 09:16:28 Wed 14-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 09:15:37 Wed 14-Oct-2009 Controller 2
. 05:25:55 Mon 12-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 05:25:53 Mon 12-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 05:25:53 Mon 12-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 05:24:57 Mon 12-Oct-2009 Controller 2
. 21:49:58 Sun 11-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 21:49:36 Sun 11-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 21:49:36 Sun 11-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 21:48:44 Sun 11-Oct-2009 Controller 2
. 20:42:36 Fri 09-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 20:42:34 Fri 09-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 20:42:34 Fri 09-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 20:41:48 Fri 09-Oct-2009 Controller 2
. 02:37:41 Fri 09-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 02:37:40 Fri 09-Oct-2009 WARNING: Unexpected shutdown, reset, or power loss detected on unit 0 on controller ID:2. Redundant units, if present, will rebuild. (0x8)
. 02:37:40 Fri 09-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
. 02:36:44 Fri 09-Oct-2009 Controller 2
. 23:00:25 Sat 03-Oct-2009 INFORMATION: Initialization started on unit 0 on controller ID:2. (0xc)
. 23:00:25 Sat 03-Oct-2009 INFORMATION: Background media scan stopped on controller 2.
