is my case ugly?
soink
i got this case not to long ago, i liked it when i saw it at the store but im having second thoughts now:
hows my wireing job? :p
The case is ok the cables all over the place are ugly. J/K
Try using some kind of cable sleeving or loom and it will look better. Also paint your drive some color or stealth i
Get a picture that is not so dark so we can see the case better
theres nothing that modding can't fix!:D paint it or something..
and please, clean the cables:cool:
There are two things about this that bug me...
1) the wiring... paging sleeving to this thread!
2) the CD drive front... I looked at it and was like WTF?
stealth it.
from what hes told me on aim his system is a follows,
A crappy ecs mobo that only supports up to 2100ddr
a 800mhz duron
a 40 gig hd
a radeon 9800pro
like 256 mb of pc133 sdram
I think theres other things that need help besides his case.
woah and speaking of somethin i was just digging through my comp stuff and i found and old 80s record, Quiet riot, come on feel the noise.
I dont think its ugly at all....alittle paint, alittle imagination and any case can look sweet.
Beauty is in the eye's of the beholder!
does that thing have a window? if no then dont worry about the wires
either paint ur drives or stealth them b/c the beige aint cuttin it :p
Actually, depending on the eye, it can be death, turned to stone, etc etc. </AD&D Mode OFF>
:D
Other than that, well, its similar to a case I have, atleast the bottom part with the power switch on the plastic. Its kinda neat. I use mine just as a server tho so it doesn't matter. :)
I agree with some of the others tho, clean up the wires! Always pretend that your case has a window in it. Oh, and yeah, and upgrade. :) Otherwise, if it works, don't fix it. (And if it doesn't, do! :)
Originally posted by kill_emma
it's not ugly persay, it's more selectivly beautiful.
HAHAHAHAHAHAHA
theres something to say to my sister teehee
yeah all i think you need to do is stealth the drives, and as long as theres no windows cable management can GO TO HELL lol
Everyone stop bs him and putting smilies... the thing is fugly and that cd drive is just wrong.
Sometimes the truth hurts.
why do you even need to ask? yes is doesnt look good right now but just a little work and effort you could make it look alot better.
start buy organizing your wires with sleeving, or split loom at the least. use the smallest tubing you can and group the wires together the best you can. also the way you route your wires even when sleeved/loomed makes a big difference.
you could also match your drives to your case with paint/dye. or an even easier way to get your drives to match is to "stealth" them. heres a couple guides, one, two. its easy, youll get the idea.
just doing those two things will improve the look of your rig significantly.
THe Case is fine, but damn that camera sucks. I seriously think that the shittay camera is making the case look worse on those pictures. As long as you didn't have a Xaser or LanBoy, I think it's fine. Also, like other said before me, your case needs a wire job badly.
