Is my Board Shot? Please Help
StringUmUp
I'm building my 1st system since the Socket-A days and having trouble.
No matter what I try in the BIOS it won't detect my sata harddrive or dvd-rom.
Specs -
GA-MA770-UD3
AMD 720 X3 BE
2X4 GSKILL DDR2-1066
SAPPHIRE 4850
SEAGATE 7200.12 500GIG SATA 3.0 HDD
SAMSUNG DVD COMBO DRIVE (SATA)
CORSAIR 400W PSU
I've flashed the latest BIOS version, and I know everything is getting power, I can open/close the cd-rom. I've tried everything I can think of in the BIOS and read all the info I could find on gigabyte's site. No matter what I try the system won't pick up the drives. I also tried my old 1.5 sata drive and that wouldn't show up etiher, but the system will register a CD-ROM attached by IDE cable.
I haven't built a system in a while, so am I just missing something, or do I need to send my board back? Thanks for any help you can give.
This is probably a dumb question, but did you connect the SATA Data and Power Cable? Have you tried different SATA port?
have you tried wit hthe dvd drive unplugged? thats about the only thing i can think of.. but it sounds like the new bios is screwed up..
Do you have the disk that came with the new MB?does it allow you to revert back to the earlier bios setup.I know you still have problems with that but,you may be able to try and update again and see if it was a corrupt update.2 bad sata cables,maybe?!
Reset the BIOS or at least make sure RAID is turned off as this may require a different setup utility.
See if that helps, I dont know your board.
