Is my BFG breaking down?
Guys i am very worried here. I bought a BFG 6600GT AGP just 1 and a half months ago. Well yesterday after starting PC fresh i started playing americasarmy, but as soon as i got into server i was experincing FPS at 3 fps when i would usually get 40 fps at least. So i went into a few other servers and i was still experiencing slowdowns, also i was spotting yellow markings occuring whenever i moved they were quite frequent. I think they were artifacts.
So to see how bad this problem was I started CSS and it was running fine, so i restarted again and played Americas Army, and guess what, the yellow glitches came back and i was getting low fps. Baring in mind last week i was running Americas Army smooth at an average of 50 fps.
Another note, after 10 mins of playing CSS i checked my GPU and it read exactly 72 degrees, is this normal?! ive never seen it this high, its usually at an average of 68 degrees after intensive gameplay.
I hope this is not the first signs of Graphics card failure?!?! :(
Try another set of drivers and if the same thing happens be glad you bought a BFG.
Its probably a sign that Spring is coming and the ambient temp is increasing :)
It does sound like the card is going bad though but try a different set of drivers.
the thing is, they were working perfectly until last nite, and today same thing happened :(
but i shall try out your advice
Make sure the gpu is in 100% contact with the cooler. Reseat it if necessary. TRy driver cleaner and try different drivers maybe?
Are all of your fans still running? While your checking that, clean those bunnies out. A good dusting never hurts.
