is my Abit Ai7 Dead?
BigTaf
Alright this is by far the weirdest motherboard problem ive ever experianced.
I was burning a CD and the computer hung, which was odd as I cant remember last time I had a crash, anyway i rebooted and it wouldnt boot
Basically when I turn it on it shows post code "83" then "84" or sometimes the opposite(84 then 83). Then it goes to 00 and shuts itself off. Ive tried the following
1)Resetting CMOS with jumper
2)Removing board from case
3)Removing peices of hardware one at a time
4)A different power supply
5)DIfferent CPU, RAM and Videocard
6)Swearing at It
she seems toast. anyone ever experiance a similar problem?
and if it is dead, as much as i liked my Ai7 i wont buy another, so how is a IC7-G as a replacement. Ill be using the following
Pentium 4 2.8e
2x512mb Kingmax DDR500 Ram
Radeon X800 256mb
If you have tried your mobo with:
a different cpu, psu, memory, video card at the same time with nothing else, and it fails to boot, chances are very good that your mobo is dead, considering you reset the cmos.
I agree. That sounds like something fried. I have hard weirder problems so im not surpised that its gone. Im am suprprised you would through alll that work and still posted here, you must really like that motherboard :p
