Is my 9800GTX DOA?
Gettys
Hey guys. I just recently did a major rebuild of my computer. Unfortunately it seems my 9800GTX is DOA, but I'm wondering if there is anything else I should try before I send it back.
I built my computer Friday night. At that time I was still waiting on my new PSU, so I decided to use my old one (OCZ 520W) that I know works fine. Unfortunately the system didn't POST with my 9800GTX. At first I thought my mobo was DOA, but then I tried my old video card (a 7800GT) and it worked fine. I figured that the 9800GTX just needed more power than the 520W could provide.
However, today I got my new PSU. It's 780W, but the computer will still not POST with my 9800GTX. As always, I've tried to get it to work with just the mobo, CPU, 1 stick of RAM, and video card connected -- still no luck. As before, everything works fine when I use my 7800GTX.
Additional things I've tired:
1) Tried both DVI ports
2) Made sure both PCI power connectors were in place
3) Reseated the video card in the PCI-e slot
4) Updated BIOS
5) Cleared CMOS
I'm really out of ideas. Any other suggestions before I initiate an RMA?
My relevant specs:
Mobo: DFI DK 935 T2RS
CPU: Intel Q6600
Memory: Muskin DDR2 800MHZ (8GB = 4x2GB)
PSU: OCZ 780W ModStream
Also, when I turn on the computer with the 9800GTX in, the computer fans/lights/etc. will start, then stop, then start, then stop, then stay on. There are no beeps or monitor activity during this process.
Man that's rough. :( It sounds like you've tried everything. Maybe try the 9800GTX in another PC to see if it works? If you have access to another PC, that's the only thing I can think of that you haven't tried.
-edit- ok do you make it to your desktop with no video? Like the windows welcome chime sound thingy? Do you hear that? If you do, try a DVI to VGA adapter and run your monitor with that. See if you get picture. It worked for me.
Only thing I could think of is maybe a PCIe 2.0 issue. Your board doesn't happen to have diagnostic LEDs, does it? If so, what does it display?
From whom did you buy your card? I ask because my new 9800GTX is dead and eVGA's tech support has been extremely helpful. When I installed the card, it ran very hot, had choppy video and game playback and scored only around 5800 in 3DMark06. I e-mailed eVGA and they responded quickly with several suggestions. When all of them failed, they immediately issued an RMA. I just sent back my card today, so I hope to have the new one by mid to late next week.
Definitely contact your card manufacturer's tech support!
