Is my 8800gt overheating?
R
ring.of.steel
Guest
when playing some games i get artifacts after about 45 mins and the computer locks up. sometimes the screen just goes blank and the monitor turns off. i have the fan speed at 85% and the card is running at 700 core 1ghz memory 1500mhz shader. it is an xfx alpha dog stock.
lower the clock speeds obviously cause you probably have the old smaller fan and it blows.. its not that effective once the cards starts to heat up.
Its not the fan that is defective, cause I run my wifes 8800gt at 60% and it never goes above 65-70 in crysis. A big problem is that in the sweatshops, they dont always apply the thermal paste correctly, you might have too much or too little.
Remove the side of the case and see if it still does it.
It does it with case on or off, tried that :confused:
Lowered back to near stock but still does the same after a couple of hours. i have the card with the smaller fan.
Got AS5 on there.
ol a bit of assuming going on there don't you think?
For all we know his machine is locking up with a overheating processor, for a start the OP has not even told us a GPU Temp.
lol a bit of assuming going on there don't you think?
The machine is not locking up with an overheating processor, never goes over 47C. Im not sure on the temps becuase ntune is being an arse with vista x64. Do you know what a stable temp range would be for this card?
Tricky answer as there are no official thermal specs.
Hitting 90C is not uncommon in fact a few here have posted stable around 100C. On the other hand a few people have posted probs with 90C.
I would say 90C is fine but undesirable. With your case side off and running the fan at 85% you "should" definitely be fine.
Does the Nvidia control panel not tell you the GPU Temp in Vista x64?. How about ATI tool?. You really need to find this out.
nvidea control panel doesnt tell the temp in vista x64 unfortunatly. im redownloading ntune and im gonna give that a go. i just had to quit cod4 because of artifacts im intrested what the temp is. im not sure if ati tool shows the temp?
Try to up the voltage like this link
upping the voltage isnt gonna help at all with overheating.
If its heating up to around 70 then its not overheating. Sounds like your card just doesnt want to run at the advertised frequencies. Try setting them to stock, and if that doesnt work try lowering them to the reference clocks. If it runs ok at reference clocks, id say RMA it. If it still does it at reference clocks i would look elsewhere also but still consider the card possibly faulty. If your CPU is fine, i would consider your ram. Ive had the situation you described due to ram not getting enough voltage as well.
Your assumption is that heat is the problem. Instability can also be caused by low voltage, either inherent in the card (VID2) or with your power supply, mobo, etc. Upping the voltage on the card to VID3 will help in your search for answers.
Mine will lock up at 700 unless I up the voltage, then it runs 24 hrs stable at 730...
Good Luck.
he already stated he ran it at stock. I say RMA it.
No, he said near stock, which is not stock, and all they gaurantee is stock, and going from OCed to near stock caused the artifact and crash time to go from 45 minutes to a few hours, according to him and RMAing at this point would be jumping the gun, wether the card is bad or not.
In his original post he said he was running it at stock.He may have meant in that post that he took his factory overclocked card to near reference stock speeds. But he would have to say for sure.
If the card does not work right at the advertised speeds RMA it.
set new clocks:
679 on core
904 on mem
1697 on shader
Seems to be fine now. should i get a better cooler and up the volts for stability?
i meant that the card was overclocked. it works fine at stock.
He said he was running it at 700/1500/1000, which is OCed, alpha dog stock is 670/975. I took stock to mean stock heatsink. Thenhe said he took it back to near stock, and it still happened.
Either way OP, if it runs ok at the preset alpha dog frequencies, your card is fine, and you will not be able to RMA it. Also, a better cooler would definitely help.
will get a new cooler, which one will be the best for overclocking?
I am personally leaning towards the Accerlo S1, or the Thermalright HR03 GT, but more so the S1 due to price. Note though, there are 3 variants of the HR03, and only the GT will fit the 8800 GT.
The S1 is much cheaper, but it is also much larger as far as i can tell and have read. I think they will cool roughly the same, but make sure you have enough room, as both of these are fairly large. If space is of concern, i would look at the Zalman VF900 or VF1000.
Also i should mention you will need to mount your own fan to the S1 and HR03. If i keep my GT, i will likely get the S1.
i was also looking at both of those 2, leaning towards the gt. space isnt really a problem so i will most likley go for the s1
nvflash doesnt work with vista x64 :confused:
and also sitting here the fan noise of the 8800gt is pissing me right off.
nvflash 5.57 is a DOS-based utility. Making the floppy using that link provided will boot your computer to DOS - independent from Windows XP or Vista. NiBiTor should work in Vista when you edit the BIOS file, but you may have to disable the driver signing cr@p, - see this thread mvktech.net thread
My card runs 730 core @ 80C under load during ATITool testing, fan set to 43%. It's quiet. Before the voltage bump I couldn't pass that test at 675 core with temp at 80C and 39% fan. I could push temps down further by upping the fan, but stability never came.
i have allways used nvflash from windows as i have no floppy drive, also my motherboard doesnt like booting from memory stick :mad:
