is my 520hx enough?
merlin87
I just put together a new computer and I reused my psu from my previous build. I do mostly photo editing and minor video editing. Dont really play too much games on the comp anymore, but like to have the option to.
Q9650 stock speeds for now
Gigabyte ep45-ud3p
8gb ddr2 1066 ocz reaper
8800gt
160gb raptor
1 optical drive
This is the basic setup for now, but I will be adding at least 2 x 1gb hard drives and may upgrade the vid card. I plan to oc the q9650 to hopefully about 3.6 on air. The 520hx has stood up great in my previous build and never had an issue with it. Its a great psu. Just thinking I should upgrade since I got new gear and wanted a modular 600-750w.
If you just want modular, sure why not. Getting modular in order to get 600-750W PSU is pointless for your rig.
It's running the Q6600/UD3R rig in my sig, I also ran that setup on an Antec Earthwatts 430w so you should be fine with the 520hx.
You might want a stronger PSU in the future if you do want to crossfire a couple of power hungry ATI cards, or use a dual gpu single slot card.
