Is MSI 6950 "Turbo" Unlockable?
*edit* Sorry, it is the HIS Turbo, not MSI.
http://www.newegg.com/Product/Produ...4161359&cm_re=his_6950-_-14-161-359-_-Product
Can this be unlocked? It is different from the standard ref card in that it comes factory clocked to 840 instead of 800. I'm wondering if there might be any other differences too, because I don't think I have found a solid confirmation that it can be unlocked, and on some sites it is even cheaper than the standard ref card, which is odd.
It looks like it says AMD on the pcb and the cooler looks like a reference one if that helps.
