Is liquesce a good data pool option?
I use it to combine a dozen 2TB drives, it's quite slow so I use it mostly to see what I have in one view, but often I'll end up searching for the stuff directly on the drive where it is.
Yes, It doesn't hide the drives. In fact you have to be careful to avoid operations between the pool and a single drive that is member of the pool as it can have unintended consequences.
I advise you install and try it, it's really not intrusive as other pooling softwares can be.
Can you just remove the drive letters (possibly mount as folder) in DiskManager then still use them in liquesce?
