I have two triple 120 xspc rads. I have 3x gentle typhoon ap-15 on each of them in push. Now I was wondering if anyone knows or has thought on if its practicle to go push/pull on each or is it not cost effective to justify the cost of 6 more GT's.
I like to think of it as "low and slow" - consider as the water is going through the block, it needs time to absorb the heat as it passes, if you are shoving the water through at breakneck speeds - its not sucking any heat out. Same goes at the cooling end - if the water is ripping through the rad and not giving the time for the fans to suck the heat out of the water as it passes through - your cooling efficiency just went into the toilet. So if you wanted to do something to better improve your cooling - I would consider flow rates first. Just my two cents - hope it helps.
physics fail above re pump speed
I like push pull because I can run all the fans a bit slower for the same effect
This is fundamentally wrong advice.
Personally I set my ERM unit on a pump speed of 3 I get terrific performance, I can stress and game for hours without ever exceeding 55-59c on most everything. I kick the pump to 5-6 and my temps go up, I kick the pump up more and my temps go up, I drop my speed to 1-2 and my temps go up. I find 3-4 is my magic setting for pump speed.
